Rack DSP order in mixer
jsonio
Post by jsonio »
I have a very simple question :
Can you confirm that the sound signal in a channel mixer in PF is going from bottom to the top
I mean : input -> (first dsp) AGC -> DSP 1 -> EQ -> DSP 2 -> COMP -> DSP 3 -> DSP 4 (last dsp)
It seems clear but i'm confused because in DAWs, the direction is usually from top to bottom :)
It's just to be sure :)
Thank you a lot in advance,
Re: Rack DSP order in mixer
Yes, the priority order of the DSPs is exactly the order you described.
