GPIO-CLIENT 4.2.3.0
Frank1977
GPIO-CLIENT 4.2.3.0
Post by Frank1977 »
HI Bernd,
I have a question about the Gpio-client Presets.
Where can I delete or find the map of the presets from the ember+ mappings?
I have now 3 different presets but I want only 1 presets so I want to delete the other 2 presets from the mapping ember+.
Kind Regards,
Frank Smit
Re: GPIO-CLIENT 4.2.3.0
All mapping files are contained in the GPIO client's config folder.
The ember files are called "*.emb"
Frank1977
Post by Frank1977 »
Thanks!
I do not have the GPIO client's config folder. Is this maybe a hidden folder on windows in program data or is this build if you started proppfrexx?
No. It is the default appuserdata folder.
%appdata%/radio42/ProppFrexx GPIOClient/4.0
Frank1977
Post by Frank1977 »
Beautiful!
Thanks Bernd.
Greetings, Frank
rbsradio
Post by rbsradio »
this morning we had a CORRUPT Gpio file. We had to delete it.
We are using the last version of Proppfrexx.
The GPIO config file is only written, when you change some settings (Note, that in this case even a .bak file or created for security reasons).
Have you just changed your GPIO configuration?
If not, a file can only get corrupted, in case of a hardware failure, as else, it is only being read.
Have you checked your hard disk for any defects?
