Listeners count
Radiofreak
Listeners count
Post by Radiofreak »
Hi i have a source adress where i can see my listners count. See below how this adress looks like. Can i use this in PF?
http://source:YOURPASSWORD@YOURICECASTS ... /YOURMOUNT
Re: Listeners count
You can use the build in function of a ProppFrexx streaming server to retrieve the listener count.
You might, in the streaming monitor window, configure all your used streaming servers (even if you don't connect them for active streaming) and use your admin credentials to collect all individual listener counts from your servers.
You can then use the ${streamingtotallisteners} macro to log the total number to either your playlist or global log for reporting.
The logs can be configured in the general settings, section Logging/History.
All macros are listen in the Appendix of the User Manual.
Click on the '?' mark icon at the very top right of each configuration dialog to get further detailed help to each option.
Radiofreak
Re: Listeners count
Unfortunately I can't get it done. I have tried all options. It is strange because the url I mentioned earlier does show the listening numbers. Which boxes must be filled in exactly? I understand it is not a software problem. Maybe someone who also has Icecast and can indicate the correct way. Thanks
Re: Listeners count
Please click on the '?' icon in the streaming server configuration dialog.
To manually (without starting the streaming) retrieve the listener count/statistics you must provide the admin credentials!
Radiofreak
Re: Listeners count
Up and running! Thanks again Bernd ;)
kruse
Re: Listeners count
Post by kruse »
I have a similar problem, but my streaming provider have given me Broadcast password, admin credentials and admin password, and something called Stats, which says nnnnnnnn: 100.
After reading the help text, I still can't figure out where to place the Stats.
Re: Listeners count
Nowhere in ProppFrexx - then can be used to retrieve the stats manually.
Just provide the source and admin credentials in the ProppFrexx server config credentials and you are good.
kruse
Re: Listeners count
Post by kruse »
Hiya,
I have added all the information I needed - I thought - and i see the listeners count on the Network Streaming Monitor, but I cannot see it in the report. I do not understand what more to do, as I
In the Global Logging, Log File Entry I have added "${streamingtotallisteners}" in the end:
${effectivestart} ${tracktype} ${filenameandpath} ${effectivesec} ${artist} ${title} ${album} ${albumartist} ${year} ${genre} ${grouping} ${isrc} ${composer} ${conductor} ${copyright} ${publisher} ${lyricist} ${producer} ${streamingtotallisteners} ${remixer}${CRLF}
In the Playlist Logging, Lof File Entry I have added "${streamingtotallisteners}" in the end:
${now}, "${event}", "${tracktype}", "${filenameandpath}", "${artist}", "${title}", "${album}", "${albumartist}", "${year}", "${isrc}", "${grouping}", "${mood}", "${rating}", "${isrc}", "${composer}", "${conductor}", "${copyright}", "${publisher}", "${lyricist}", "${producer}", "${remixer}", "${bpm}", "${effectivestart}", ${durationsec}, "${streamingtotallisteners}", ${effectivesec}${CRLF}
Re: Listeners count
I am currently on holiday - so I can test when I am back.
Osric
Re: Listeners count
Post by Osric »
Was there any further update with this? I have added the logging parameters but am unable to achieve listener numbers from my shoutcast server when accessing the .stat files to run reports.
Proppfrexx doesn't seem to pick up my active listeners, so am trying to troubleshoot. I have stopped using an external encoder and am using the Propfrexx streaming monitor and active listeners still aren't showing. Have checked my shoutcast server (Radio.co) logins and they are correct.
Any other things I can check?
