Swapping HDD and license
phonic
Post by phonic »
I'm going to be changing the one of the studios PC boot drive to a 4tb m.2 SSD, but first need to know if the license on ProppFrexx will be invalidated. I know from experience that changing the machine name to something more meaningful had that affect. As we have multiple licenses on the same e-mail address, I need to ensure any reissuing if needed does not take down another studio due to reissuing the wrong license.
Re: Swapping HDD and license
Just swapping the HDD but not changing the computer name, CPU or main memory won’t change the ProppFrexx Ident-Number.
Else, see here:
https://www.proppfrexx.radio42.com/foru ... f=5&t=2770
phonic
Post by phonic »
Thanks for the reply.
Yes in this case only the type and size of drive used will change not the CPU or memory, etc. I will go ahead and start the work.
However, in a coming upgrade maintenance the memory on the main system is to be upgraded, so I guess that may trigger a new Ident.
