Jingles not in play now
Soulmaster
Post by Soulmaster »
Howto switch of the jingles name in de now playing ..
Re: Jingles not in play now
?? Do you mean to disable to use the Jingle name in the Streaming meta data for your streaming server, i.e. not to update the song title with the jingle ??
If yes, go to the general settings, section Streaming any select the 'Jingle' entry type in the 'Exclude from Title Update' selection box in the Song Titles group.
Make sure your Jingles are properly tagged and are using the Jingle media entry type!
Soulmaster
THNX!!!
