Change name voice track recording!
yourx
Post by yourx »
Question, how can I change the name of the voice track recording.
Now it says after recording voice over, Name: user Title: VREC_20201127_121145.
In addition, listeners also see this text, there is a possibility to hide this information.
Groet Henry ;)
Re: Change name voice track recording!
When you do voice tracking you can directly set/change that filename in the voice tracking dialog.
yourx
Post by yourx »
Thanks for your explanation I understand the title but it is the name of the recording that is important to me, this is now called user where do I change this.
Just use the normal TAG Editor (click on the "TAGs" button) to modify the title, artist, whatever meta data you want...
yourx
Post by yourx »
Thanks Bernd for your answer, so there is no default username to set?
Maybe an idea to be able to enter a DJ name at the voice recording window
No, currently, there is no default name to be configured. but I can take a look to add one?
yourx
Post by yourx »
Thanks Bernd!
I added support for that requirement in v4.2.3.0.
Open the Change User Settings... dialog (at the top right, under the user icon) and see the new 'A' and 'T' icons behind the Recording Filename.
Here you can now define a default voice tracking Artist and Title - incl. using any global macros!
yourx
Post by yourx »
I have installed the update and it works great.
Thank you very much for the adjustment Bernd.
