Cd cover
Bob Van Dongen
Cd cover
Dear Bernd
I had the following question what are the possibilities to make the CD covers from the tags visible in proppfrexx?
greetings Bob van Dongen
Re: Cd cover
Cover Arts are already available!
When using the TAG Editor, you should see them.
And you can add the column ‚Cover‘ to your playlist.
Eg. use the ‚Show Column Chooser‘ from the Playlist ribbon tab.
Once you changed the playlist column layout, make sure to save it! Else it would be lost when you close the Playlist.
