Mixer
This forum is unmoderated!
97underground1
Mixer
Post by 97underground1 »
Ok I need an answer. My veiw of the mixer and clock have disappeared. When you click the mixer icon in the left hand corner nothing happens . Does ANYONE know how to get the mixer back into a floating or docking mode. The manual and videos do not address that.
Re: Mixer
Yes, like already explained here:
You probably need to reset your layout.
http://www.proppfrexx.radio42.com/forum ... 723#p14484
You probably have moved the window to an invisible section. Or you are switching between a multi monitor setup or it got hidden in the background behind another window.
And again, all ProppFrexx related question should NOT be asked her, but in the Question & Answer section.
