short on script lines
This forum is unmoderated!
D3R3K
Post by D3R3K »
Brnd i noticed today the the proppfrexx player is supposed to run 28 script lines its now running only 22 and then stops playing. also when I test a script it takes an extremely o
long time to generate the test and then only shows me 22 not 28. What can I do?
Re: short on script lines
When using the 'Test' function the script, you'll see an output text once it finishes. This should typically indicate the error reason.
If you are unsure about it, please send me the full output.
But typically a slow test run indicates some issues, probably a history setting is too strict and prevents a script-line from being able to return valid tracks matching all criterias. Unless you specify the script option 'UseLastTrackOnFinalFail', that script-line is than skipped.
