Commercials
jam1508
Commercials
Post by jam1508 »
Hi
Why is it when you setup Advertisement on one proppfrexx software
the same advertisement is setup on other stations as well
Using script
only da commercials music,jingles is ok
Its the same with programing
if I program a Xmas show for listeners over 30
why does the same program setup automatically in the music scheduler for listeners 16 to 25 station
Regards
Re: Commercials
Sorry I don't get your question?!
What are other stations?! I assume you are talking about different PCs/Instances of ProppFrexx?!
Can you please describe your exact setup? And how you use different ProppFrexx instances to manage your multiple stations?!
Each ProppFrexx instance can be configured to use its own Advert Storage Path (a folder in which all adverts, news etc. and the overlay calendar is hosted) as well as it uses individual program scheduler calendar (file).
If all your stations use the same folder resp. file - than each change is reflected of course in all stations.
If they use different folders/files - than nothing is shared between those instances!
