Rotation of music
D3R3K
Rotation of music
Post by D3R3K »
Bernd: Tom here from 97Underground.com. We are having a problem rotating music tracks in your software.
The set up is this,
We have 10 tracks in a category (media library).
There are 3 script lines per hour that call for this category.
All of the script lines are set to sequential.
We are trying to accomplish the following:
Hour 1 plays track 1, 2, 3
Hour 2 plays track 4, 5, 6
Hour 3 plays track 7, 8, 9
Hour 4 plays track 10, 1, 2
Unfortunately it does not cycle entirely and some tracks are playing almost every hour while other tracks are not getting any play. I believe it has something to do with history settings or suppress history check. I have tried both suppress history check and force library check but not reaching desired results. Do you suggest another setting or settings that I can use to rotate this music properly? Tom
Re: Rotation of music
When using the Sequential script-line mode, have you set the SuppressHistoryCheck and SuppressAddHistiry option with those script-lines?
If yes, you might use the Script Test function maybe between the 1st and 2nd hour to test, why it is not working.
