Streaming
97underground1
Streaming
Post by 97underground1 »
I am having a great deal of difficulty getting proppfrexx to see the icecast server. All the codes are in. Im assuming the ON AIR should be lit if the system is working. Can any one lead me through this process? Tom
Re: Streaming
You probably have something not configured correctly.
You might start with the streaming server configuration, e.g. post a screenshot.
Then check, if you have configured the encoder properly etc.
Re: Streaming
I just saw your screenshot, which you posted via eMail (sorry, but personal eMail support requires a support contract).
However, in your streaming server configuration you used your name as the 'Username'. By default ICEcast uses the user 'source' - so you might want to empty that field and try again.
Are you sure, that you configured the source streaming user to be different than 'source'?
Else, please make a right-click on the entry in the 'Network Streaming Monitor' window and select the menu entry 'Show Error Details...' - what does this say?
In addition you can watch the ICEcast server's log file to see further details, why the source connection might be refused.
This should give you more details about possible reason.
Please post details here, if you can still not make progress.
Re: Streaming
It is up and running fine now.
