Working with the FindExpressionBuilder
The 'FindExpressionBuilder' is an extend way of defining serach resp. filter criterias.
It can be used from either the 'Find' window or within the 'Script Editor' to define a filter for a certain script-line.
It can be invoked in both cases by clicking on the '?' button; and looks like this:
This editor allows you to build complex filter criteria with an unlimited number of filter conditions, combined by logical operators. You can switch between a Tree-Like or text-based filter editing style.
In the above screens example the resulting text based filter would be:
StartsWith([Grouping], 'top') And Contains([Grouping], 'opener') And ([Genre] In ('soul', 'jazz') Or Contains([Mood], 'mellow'))
As you can see the top root node logical operator defines the initial one and any child group operator defines the behaviour for its childs.
Note, that unless the 'Case-Sensitive' option is checked all comparisions are case insensitive!
There are two filter extension function, which can (currently) only be added in text mode only, which are:
  • ContainsAnyOf([field], <list>)
  • MatchesAnyOf([field], <list>)
Where "ContainsAnyOf" checks, if any of the list parameters are contained in the first field parameter; and "MatchesAnyOf" checks, if any of the list parameters does word-match the first field parameter.
Examples:
"ContainsAnyOf([Artist], 'Madonna', 'Prince')"
"MatchesAnyOf([Artist], 'Madonna', 'Prince')"
Note: Instead of specifying a <list> you might also specify a text file location containing the list element values. The filename must be specified with a preceding '@'-sign. Each element must be placed in its own line within the referenced file.
Example:
"MatchesAnyOf([Artist], '@C:\Filter\artistlist.txt')"
