v4.2.1.0 - stable
v4.2.1.0 - stable
Version 4.2.1.0 is out!
What's New?
  • new UI lib version used
  • new Audio lib verion used
  • LoadTrack/URL now also supports Podcast URLs
  • Cartwall now supports 3 sizes: Small, Medium, Large
  • new Cartwall double-cick modes added: None, Play Cart, PFL Cart
  • Force Compression added to Remote Voicetracking sessions
  • Remote Voicetracking user/password now validated against UAC users
  • TCP Limits (IP, user) now also used for all GPIO Ext. Service
  • new TAG Last Read playlist column added
  • Rescan of playlist media libs now doesn't remove dead tracks
  • Rescan bug-fix not reading all meta-data
  • Loading speed of Advert-Lib improved
  • Timecode window now also shows Standby Ramp/Outro time
  • ANYOF and CATEGORY now also supported for Sequential script-lines
  • ALT+DragDrop now also spported within a playlist (Convert to Sweeper)
  • Find Windows is slow on certain sortings bug-fix
  • Create Embedded Hook-Containers now support using a dedicated Media Type for all tracks
  • duplicate playout in some cases when using a FTE AsOverlay bug-fix
  • additional mAirList compatibility for meta data reading
  • JMD tag reading bug-fix
  • Track-Event bug-fix when already loaded to DJ-Player
  • Insert-Events might be played out twice bug-fix
  • new overlay macros added
  • OverlayPriority and ProgramPriority added to .importformats
  • stable
Re: v4.2.1.0 - stable
Restore the layout. Either via the general settings, section Look and Feel.
Or close PF, locate the file „ProppFrexx ONAIR.layout“, and restart PF again.
