remote voicetracking
atlantic
Post by atlantic »
I have two questions about remote voice tracking.
Is it possible to give each user their own password. so you don't have to change the general password when someone stops remote voice tracking.
Is it possible to always set the download music in low biterate, so that the DJ himself cannot choose.
Re: remote voicetracking
Currently all use the same password, and also the client defines the quality.
But I understand your requirement and it makes sense, so I'll look into implementing this!
Should now all be working in the new v4.2.1.0.
A new 'Force Compression' option was added to the server sided RVT options (see general settings, section Encoding/Recording)
When you have UAC enabled (Enterprise Edition), you can now use the individual usernames/passwords of the server as well for the remote client connection (same user, same password) to assign individual credentials.
In addition, the TCP - Limit (see general settings, section GPIO) is also honored for any RVT session.
