error log?
LESH FM
error log?
Post by LESH FM »
Hi all,
just wondering how i access the error log?
I had a file yesterday that was jumping and clicking and i found that the script didnt load the entire script but i would like to see the actual error
an eventual reload of the program fixed the program but be good to understand the issue
LESH FM
Re: error log?
Post by LESH FM »
also the "out" volume wasnt being sent out - it was playing on the screen but it wasnt playing out of the system... strange :(
Re: error log?
The log files can be access from the Tools ribbon tab. See the Shiw Log Files ribbon button.
However, the other things you described sounds like either a sound card issue or a config issue in the related mixer channel. If an Out of a mixer channel is not heard, please check, if the correct device is selected and also check the windows device/mixer settings, not, that it is accidentally muted in the windows settings.
