Recurrence
Soessafaria
Recurrence
Post by Soessafaria »
when I select a weekje recurrence of an overlay I can select which days it will recur.
I would like a similar function for the daily recurrence to select at which hours it will recur. For instance I would like the traffic to play daily at 6,7,8,9,10,11,12,13,14,15,16,17 o'clock.
Would that be possible?
Re: Recurrence
As this is 'recurrence' function is unfortunately a build function of a UI component I am using, I have no influence on this.
So for different hourly recurrences, you simply need to copy and double the overlay.
In your case actually 12.
BUT...
...typically overlays are used for Advert-Slots and with Adverts it is actually recommended to to separate then into individual insances, as otherwise you can not really assign different adds at different times!
Same for Top-of-the-Hour Jingles - you maybe want to define them differently, e.g. use different Jingles for different time, like 'good morning', 'good afternoon'...
