VT mixer setting
Radiofreak
VT mixer setting
Post by Radiofreak »
Hello, I would like to voice track. I want to do this while PF is in automation mode. Now I have a PLAY, OUT and PFL mixer channel. In addition, a MIC channel. I work with an analog mixer. My question is how do I organize the mix channels because I can't get it done. I've seen Bern's tuturiol on Youtube but that's with asio. I work with a 7.1 soundcart.
Re: VT mixer setting
I don’t understand your issue?!
What is your problem exactly?
For VT you can use your MIc channel as input and your PFL channel as output.
Or is latency your issue, having a delay between output and input?
Your might try Asio4All if latency is your issue.
