Sluggish Performance After Win 10 Update
D3R3K
Post by D3R3K »
Windows 10 recently did an update and since then ProppFrexx runs extremely sluggish. Could take up to a minute for the last track played to disappear from the player after finished. The countdown timer freezes for periods of time.
Also, how do you get the program to start playing immediately after loading? If I open up ProppFrexx say at 6:03pm, the countdown time says NEXT PROGRAM -57:00. I dont think it was doing this upon the initial install so i must have changed something somewhere. Thank you for your help.
Re: Sluggish Performance After Win 10 Update
That’s sounds like an issue on your system rather than a ProppFrexx issue!
Almost all users are on Win10 including myself, and so far I am not aware of any problems.
Maybe the update corrupted some of your system settings. Eg. you might try to repair your .Net framework? Or check you disks? Reboot the PC...
