Connecting Radiocaster with Proppfrexx (Artist - Title)
codo1215
Post by codo1215 »
Hello all,
I work with Radiocaster as encoder, because i use Stereotools as DSP. This is working fine. Now i'm searching how to connect Artist and Title from Proppfrexx to Radiocaster.
Has someone any idea how to fix this?
regards in advance,
CoDo
Re: Connecting Radiocaster with Proppfrexx (Artist - Title)
Yes, directly use StereoTool inside ProppFrexx as a DSP/VST of your primary mixer output channel and also directly stream from ProppFrexx to your streaming server.
Then you do not need Radiocaster anymore at all.
Else, I am afraid you should ask Radiocaster how they are able to receive songtitle updates.
ProppFrexx could theoretically write a text file, send a text via TCP/IP or send HTTP GET or POST request etc.
codo1215
Post by codo1215 »
Bernd,
Thanks for your answer. I tried to load the VST on the primary mixer output. but when ik restart the programm it gone. Radiocaster is able to look at a text file. but how do i config a text file in PF with one line or the latest song at top?
Did you load the correct latest VST in e g 64-bit from StereoTool ?!
Many many users do that and it works fine for all of them. So there must be an error on your side I am afraid.
