Main mixer question
SiriusRadio
Main mixer question
Post by SiriusRadio »
We have been using proppfrexx for several years and have again purchased an analog mixer. We first had a D&R airlite.
Now that I have that mixing table (Dateq) I run into a general problem. I want to remove all mixers from my main mixer and set everything up again. But that is quite a hassle, in fact, it does not work well.
My question is therefore as follows.
How can I make a fresh new setup? Is that only possible by removing and reinstalling PF?
Will
Re: Main mixer question
To make a fresh mixer setup, simply close PF, go to the ProppFrexx AppUserData dolder(eg.%appdata%\radio42\ProppFrexx ONAIR\4.0\) and delete the file called “Default.mixer”.
Then restart PF.
You’ll then be asked to setup your mixers from scratch.
SiriusRadio
radio42 wrote: 29 Jul 2020 13:28 To make a fresh mixer setup, simply close PF, go to the ProppFrexx AppUserData dolder(eg.%appdata%\radio42\ProppFrexx ONAIR\4.0\) and delete the file called “Default.mixer”.
Then restart PF.
Thxs, already fixed
