EXEC_SEND_TCP stopped working
fred48fm
Post by fred48fm »
Since some time we expreience troubles using the EXEC_SEND_TCP command.
Did anything changed in the command syntax ?
The command is used to update the RDS data and look like :
EXEC_SEND_TCP SERVERIP:PORT|DPS=RDS DATA ${CRLF}${CRLF}
The command work using other tcp softwares.
Any idea ?
We use this with a Deva RDS encoder.
Thanks in advance
Fred
Re: EXEC_SEND_TCP stopped working
Nothing was changed since many versions!
So if it used to work before, I assume some changes in your network, firewall etc. ?
fred48fm
Post by fred48fm »
That's weird.
Nothing really changed (tryed on 2 computers and 2 different networks).
The strangest part is that the script is sometime executed correctly for long time, before being ignored for hours.
In the meantime, i solved this by moving this command to an external tool "packet sender", with the exec_shell_command.
The exact same command using this tool work successfully everytime.
Thanks for your time,
Fred
Maybe a virus scanner or any other blocker which stops it silently.
So if I understand you correctly, it works fine for a longer time, then it stops for some hours and finally it works good again?!
That however doesn’t sound like a software error.
atlantic
Post by atlantic »
We also have a Deva RDS encoder.
How can you have a slogan and now playing alternately appear on the rds.
We use right now
EXEC_SEND_TCP SERVERIP: PORT | DPS = $ {artist} - $ {title} $ {CRLF}
Many RDS encoders support alternating text tru special text sequence. E.g. ST: http://help.stereotool.com/rds_encoder_texts.shtml
I am not familiar with the Deva product, but maybe it also supports something like ST does?
But ProppFrexx doesn’t support this internally, as it is not an RDS encoder.
