Editing Script
Radiofreak
Editing Script
Post by Radiofreak »
Hi, i like to edit a script what already is playing and scheduled. E.g a script for the weekend is running but in the mean time i just want to change some script lines or jingles. Is this possible?
Second question, i would like to see the Ramp time in the collum above the playlist. Maybe there is this option but i can’t find it.
Re: Editing Script
Yes, but you need to enable that in the general settings, section Scripts/Scheduler - check the 'Allow Edit running Scripts'.
The Ramp and Outro columns are contained in the 'Meta Data' band. To see this band in the Column Chooser, you must first show the Band Column Headers, see here for details:
See here: https://www.proppfrexx.radio42.com/foru ... 252#p10252
Also note, that you must manually save the layout once you changed the columns, e.g. look at the 'Miscellaneous' ribbon tab and click on the Save Layout button!
Radiofreak
Re: Editing Script
Set and done! Thanks Bernd.
