Problem v4.2.0.3
Kekke
Problem v4.2.0.3
Post by Kekke »
I updated to this version.
Now I get this error : c:\windows\system 32\mfreadwrite. DLL error fault 0xc000012f
Also it doesn't save my layout settings..
Anyone?
Re: Problem v4.2.0.3
That sounds like something on your system is corrupt?! Drive error ?
Or it might mean, that you installed a 64-bit version in a 32-bit OS?!
Mfreadwrite. dll file called "Media Foundation ReadWrite DLL" is a part of Microsoft® Windows® Operating System program. ProppFrexx need this file to work properly. So it might also be, that this got corrupted with the last Windows Update (not the ProppFrexx update!).
Kekke
Post by Kekke »
radio42 wrote: 02 Jun 2020 21:04 That sounds like something on your system is corrupt?! Drive error ?
Ok thanks for the fast response.
I check the system!
