Dropouts by play from Videoclips
Djharzerroller
Post by Djharzerroller »
Hello friends, since I have a lot of current music as video clips and now use them more often, I have dropouts when playing. Can someone tell me how I can change that.
Sound cards is set with WASAPI 44100hz. Both at the exit to the web station and at the input to send.
Re: Dropouts by play from Videoclips
That might have many reasons, eg. a too small audio buffer (which you can increase in the mixer output channel).
But if this only happens with video files, then also take a look here: https://www.proppfrexx.radio42.com/foru ... ?f=5&t=915
You can also test, if your system has latency spikes (see the above like for details).
Could also be, that your IO-system is too slow, eg. if you play the tracks from a slow network or usb drive.
Djharzerroller
Thanks for Information, i am check this
