Track insert attenuation
franksiegers
Post by franksiegers »
Hi all (Bernd),
I regularly use Alt-drag to add a sweeper as track insert to a track. The edit special element windows opens with a default attenuation of -12 dB. Is there a way to change this default to 0 or disable the attenuation?
BTW: I noticed Alt-drag does work when I add a sweeper from one of the find windows, but not when the sweeper is already in the playlist (added by script) and I like to move it from "standalone" to "track-insert". Is this by design?
Cheers,
Frank
Re: Track insert attenuation
Yes, general settings, section Mixing/Fading - click on the 'Attenuation Settings...' button.
Yes, this is currently by design (I might check, if I change this- not sure yet) - but you can use the CRTL+R combo to convert a playlist entry to a Sweeper (using your default Sweeper Mode - see general settings section Mixing/Fading).
