Remove script PFS
jsonio
Remove script PFS
Post by jsonio »
I've a really simple question... I would like to remove some scripts from my library but the button "remove" stays grey when I select the script.
How can I remove it?
Thank you a lot in advance,
jsonio
Re: Remove script PFS
Maybe you have selected a script library, which was loaded automatically and isn't a manually managed lib (category name would be AUTO)?!
I assume, that you have provided a folder path in the general settings, section Scripts/Scheduler in the 'Auto. Script Path' ?!
Note, that ProppFrexx will load all .pfs files in this path automatically. I.e. you might want to remove this path and only manage the script libs manually instead.
Click on the '?' mark icon at the very top right of the dialog to get more help!
jsonio
Post by jsonio »
I confirm it is an automatically added Library! I clicked on the "?" and read the help before posting but i'll read it again ^^
Thank you !
