Proppfrexx not responding.
Erris
Post by Erris »
I use next to Proppfrexx the Proppfrexx ONAIR watcher, today Proppfrexx was not responding, Proppfrexx is running on Windows server 2016 with 16GB mem and 16 cores so this should be enough for Proppfrexx to run properly
Error log ONAIR watcher:
2-5-2020 12:13:22 WARNING: ProppFrexx ONAIR is not responding anymore!
2-5-2020 12:13:27 INFO: Restarting C:\Program Files\radio42\ProppFrexx ONAIR\ProppFrexx ONAIR.exe
The error log of Proppfrexx did not say anything about an not responding.
The question is what could start to interrupt Proppfrexx on the server only Proppfrexx ONAIR, Proppfrexx ONAIR watcher, a download tool and a virus scanner.
Re: Proppfrexx not responding.
When there is no error in the ProppFrexx error.log, this is typically an indication, that the system itself is unstable. Eg. a buggy sound card driver, an IO error, a network issue, a graphics driver, the OS itself etc.
The Windows Event Log might reveal more info. Have you taken a look there?
Also, what exakt version and license are you using
Erris
Post by Erris »
I'm going to check the event logs of windows, thanks for the tip
I'm using 4.1.5.13 64-bit Licence prof.
Erris
Post by Erris »
Hi Bernd Found the problem it was windows some .dll problem, hope i fixed it :) thanks for the support anyway
Erris
Post by Erris »
Morning Bernd, i upgraded ProppFrexx to 4.2 but i got this in the event log
Error Application Name: ProppFrexx ONAIR.exe, Version: 4.2.0.0, Time Stamp: 0x5eba9f9c
Error module name: KERNELBASE.dll, version: 10.0.14393.3630, time stamp: 0x5e8d43a3
Exception code: 0xe0434352
Error margin: 0x0000000000034c48
ID of process with error: 0x5f0
Application start time with error: 0x01d628eca3bb6cc1
Faulting application path: C: \ Program Files \ radio42 \ ProppFrexx ONAIR \ ProppFrexx ONAIR.exe
Error path to module: C: \ Windows \ System32 \ KERNELBASE.dll
Report ID: 53512f24-6576-472e-9187-3de4aa6b5bca
Full package name with error:
Package Relative Application ID with Error:
Erris
Post by Erris »
Here's an other one
Application: ProppFrexx ONAIR.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
at DevExpress.Utils.AppearanceObject..cctor()
Exception Info: System.TypeInitializationException
at DevExpress.Utils.AppearanceObject.ResetDefaultFont()
at DevExpress.Utils.FontBehaviorHelper.Update()
at DevExpress.LookAndFeel.UserLookAndFeel..ctor(System.Object)
at DevExpress.LookAndFeel.UserLookAndFeel.EnsureDefault()
at DevExpress.LookAndFeel.UserLookAndFeel..cctor()
Erris
Post by Erris »
I even reinstalled Propp
Soulmaster
Post by Soulmaster »
same here
In all my test systems I am not getting this - so I need to investigate...seems, that some .Net dependency is missing on your systems...
Can you please use the attached zip file and unpack it to your default ProppFrexx installation directory, to check, if this is the missing file resolving your startup issue?!
DevExpress.Data.Desktop.v20.1.dll.zip
(158.8 KiB) Downloaded 456 times
