HTTP GET/ POST / Plain ???
moogwill
Post by moogwill »
Hi Bernd, I'm trying to achieve to remote vmix on a second computer using that kind of http http://127.0.0.1:8088/api/?Function=Fade&Duration=1000 but I can't get it to work properly. can you just put me on the right way ?
Thanks,
Thomas.
Re: HTTP GET/ POST / Plain ???
Please show your exact control command you are using (which is not working currently) and also the specs what the comic expects (some expect GET some POST).
Here is a similar post, which explains a sample:
https://www.proppfrexx.radio42.com/foru ... f=9&t=1031
