Rodecaster Pro
This forum is unmoderated!
FDH02
Rodecaster Pro
Post by FDH02 »
Can the Rodecaster Pro with the new 2.0 firmware be used for VT's with ProppFrexx?
https://www.rode.com/rodecasterpro
Regards
Re: Rodecaster Pro
Not sure what special requirements you have.
But if the Mic is visible as e regular input device in Windows it can be used yes.
For the console features I haven’t tested myself.
FDH02
Re: Rodecaster Pro
Post by FDH02 »
I mainly use "remote voice tracking", so I only need 1 audio line and 1 mic line.
When I watch this video at minute +/- 4:10 sec, I suspect this is possible over the single USB connection.
"Edited" Correct URL > https://youtu.be/gvjGQcCWk1c
I think this "Rodecaster Pro" is quite an interesting product and has maybe even a number of advantages over the "D&R Webstation".
Taking into account that I am a DJ and not a radiostation in itself.
Re: Rodecaster Pro
The 4 mics seems to be processed internally.
So the USB device only send 1 Output and 1 Input over USB.
There are pro soundcards doing much More.
FDH02
Re: Rodecaster Pro
Post by FDH02 »
Since the last update, its a multitrack recording in which you record each track separately over the USB.
But perhaps the D&R Webstation is a better choice, food for thought..
Re: Rodecaster Pro
I guess both are totally different having different target customers.
