Find Track Doesn't Opens
marinohb
Post by marinohb »
I'm trying to open the sidebar through View>Find Track. Also, either the Mixer and any CartWall Opens
Re: Find Track Doesn't Opens
What exact version are you using?
However, what you can try is to close ProppFrexx and then delete a file called „ProppFrexx ONAIR.layout“ located in the AppDataUser fiolder (ie. %appdata%\radio42\ProppFrexx OnAir\4.0\) and than restart it.
marinohb
Post by marinohb »
I did that and it doesn't work. My version is 4.1.5.8
did you delete the file AFTER ProppFrexx was closed?
I.e. close PF, delete the file, start PF again...
