Questions about PowerGold and Proppfrexx
angelfigueredo
Post by angelfigueredo »
Hello how are you? I have a doubt, if I want to use the powergold programmer, how can I import proppfrexx files because only powergold allows me to import in ".TXT" format and not in ".CSV"
How could I do right now?
Re: Questions about PowerGold and Proppfrexx
What do you want to import into PowerGold?
Normally it is the other way around, ie. you import PowerGold log files (the schedules) into ProppFrexx.
This is explained here: viewtopic.php?f=9&t=701
(Note, that the example is using Music1 as your external scheduling system, but PowerGold is equally fully supported)
angelfigueredo
I say import the music library from proppfrexx to powergold, I know how I can export in CSV, but how I import it in Powergold if it only allows in .TXT
angelfigueredo
For a better explanation, powergold does not allow me to import the proppfrexx media library in ".CSV" format. It only allows me in ".TXT" mode.
The .csv format is a text format with values separated by a separator char. I assume, that PowerGold should be able to import that.
But this something to ask their support I am afraid ;-)
