TCP question
Thijmen
TCP question
Post by Thijmen »
Hi team,
I am trying with the TCP module to queue a track at the bottom of the playlist, move it up and then load it to a deck.
I am doing this while the playlist has 10+ items, so there is a queue.
I am able to put it on the playlist, move it up to position 2 but I don't get it to load on a player.
What I would like to archieve is the same behaviour as you drag a file on the bottom of the playlist, and move it to position 2. When I do that manually, it gets loaded to a player.
Do you have any tips?
I tried: PLS_CURRENT_EJECTNOFADE_B and PLS_CURRENT_LOAD_B, but no succes..
Thijmen
Re: TCP question
Post by Thijmen »
Just a few seconds I posted this thread (and gave up...), I found out that "PLS_CURRENT_LOAD_SELECTED" did the trick for me!
Re: TCP question
