Problem with Program Scheduler
marinohb
Post by marinohb »
I updated few hours ago to 4.1.4.4. And when I'm trying to import a log file using Program Scheduler I get the following message:
"Program Calendar is currently used by: SERVER-PC/SERVER. It can not be used twice"
Everything was working okay. I want to downgrade this version ASAP. The radio is off air.
Re: Problem with Program Scheduler
No need to downgrade!
The lock file is created for multi-user access and might remain, if it was not closed properly.
When you click on the 'Program Scheduler' ribbon tab button, please hold down the CTRL+ALT key while doing so. This automatically removes any previous lock file.
Or...
See here: https://www.proppfrexx.radio42.com/foru ... f=7&t=2374
