Bulk Update Restrictions (Don't Repeat in:)
Soessafaria
Post by Soessafaria »
is it possible to update the song restrictions for multiple music files at once? We have tried to set global settings however, this does not work as we want.
We would like to make sure the selected songs won't be played for a specific number of days. (Edit Metadata - Other -- Don't repeat in X days.)
I tried to do it in the Tagger, unfortunately unsuccesfully.
Re: Bulk Update Restrictions (Don't Repeat in:)
If you only want to set a restriction on a very few tracks, you need to define those restrictions per track. There is no bulk update for this available.
Else you can of course define global restrictions and use certain meta-data filter criterias, eg. only apply those restrictions to a group of tracks having eg. the same media entry type or grouping value...
