Shortcuts in VTmodus
Bumperke
Post by Bumperke »
Hi.
I cant find the shortcuts for:
StartRec
SetNext
StopRec
All in VT mode.
Can someone tell me?
Thxs
Will
Re: Shortcuts in VTmodus
There are no specific, but you can define your own using the HotKey mapping in the general settings, section GPIO and by using the VT_... control commands (see the user manual appendix).
Bumperke
Post by Bumperke »
Working with an D&R Airlite, can you give me some hints? The Airlite needs to be regognized, right?
The D&R Airlite interface is located in the GPIO Client (a separate application), which is started, when you enable the ‘Ext. GPIO Service’ in the general settings.
Make a search in this forum and you’ll find various entries here.
What exactly are you looking for? How does this relate to Shortcuts for VT?
