PF freezes
Radiofreak
PF freezes
Post by Radiofreak »
This afternoon PF freezes off his own. Where can i find the log to send it?
Re: PF freezes
If it was a ProppFrexx related issue (which I doubt) there would be an entry in the file called „Error.log“ which is contained in the ProppFrexx AppDataUser folder.
If it was a system or any other issue (OS, driver etc.) you should find an entry in the Windows event log (are the Windows event viewer und see Application section).
Radiofreak
Re: PF freezes
ok it was not PF. It is something in windows but i have to search. Thanks bernd.
