issue with remoteview
jbmusic
Post by jbmusic »
Hi All,
i am trying to instal the PF remoteview on a seperat system.
Unfortunatly it's not working.
i get the following error
Naam van toepassing met fout: ProppFrexx RemoteView.exe, versie: 4.1.2.0, tijdstempel: 0x5d2204bb
Naam van module met fout: KERNELBASE.dll, versie: 10.0.17763.771, tijdstempel: 0xc9ffae0f
Uitzonderingscode: 0xe0434352
Foutmarge: 0x00121932
Id van proces met fout: 0x12a4
Starttijd van toepassing met fout: 0x01d57c1bb8b7f71c
Pad naar toepassing met fout: D:\software\ProppFrexx RemoteView.exe
Pad naar module met fout: C:\WINDOWS\System32\KERNELBASE.dll
Rapport-id: 841cae23-276c-47a3-8274-7e51ca1aa40b
Volledige pakketnaam met fout:
Relatieve toepassings-id van pakket met fout:
I have updated windows system etc. without succes.
I hope someone could help me out to solve this issue.
manny thanks!
Re: issue with remoteview
How have you installed it on the remote PC?!
It looks like there is a .Net error on that machine.
Make sure to install the latest .Net framework and make sure to install the exact same ProppFrexx Vernon on both systems.
Also note, that v4.1.2.0 is an older version. Eg. You might try to update to the most recent version.
