consider manual added tracks and player
atlantic
Post by atlantic »
In "global history options" / "consider manual added tracks" set "ask for detected duplicates" but this only works for the playlist. You can always put your tracks in the player without having to get this question. Is it possible to provide it for the players.
Greatings
Marc
Re: consider manual added tracks and player
Are you talking only about the DJ Players or also the Standby Players?
atlantic
Post by atlantic »
I am talking about the DJ Player A,B, C and D
Add to v4.1.4.2.-update.
atlantic
Post by atlantic »
I did the update but, you can still insert a double track in a DJ player. see move.
https://www.dropbox.com/s/r86txzj6e44tf ... .webm?dl=0
regards
Marc
I am sorry, but I cannot reproduce that here.
Maybe you have not set your Song History preferences correctly!
Please check, if your track 'Rhythm Devine' is actually added to the global song history.
E.g. you need to ensure, that the Add to Song History option is also set?!
atlantic
Post by atlantic »
Where can I find.
These are my settings.
https://www.dropbox.com/s/6fkkfmwszv3ik ... l.PNG?dl=0
The Global Song History can be found in the general settings (when you click on the label 'Global Song History:') - or in the 'Tools' ribbon tab - 'Show Global History...'.
But maybe something went wrong with the 4.1.4.2.-update - you can also get it here and unzip it completely to your official installation folder (close PF beforehand):
http://www.proppfrexx.radio42.com/downl ... te4142.zip
atlantic
Post by atlantic »
ok it works now.
with the new update
thanks
