pf crashes after some time
doobeedoo
Post by doobeedoo »
Hi
Since Thursday my proppfrexx starts up normally, start playing and then crashes after some minutes.
There is nothing in the proppfrexx error log.
I found the following entries in the windows application log (sorry it's in Dutch)
- <EventData>
<Data>ProppFrexx ONAIR.exe</Data>
<Data>4.1.3.1</Data>
<Data>5d66ce7d</Data>
<Data>msvcrt.dll</Data>
<Data>7.0.18362.1</Data>
<Data>f5bdefd7</Data>
<Data>c0000005</Data>
<Data>00000000000747a0</Data>
<Data>1dd4</Data>
<Data>01d56b14cb328519</Data>
<Data>C:\Program Files\radio42\ProppFrexx ONAIR\ProppFrexx ONAIR.exe</Data>
<Data>C:\WINDOWS\System32\msvcrt.dll</Data>
<Data>a89bccc8-24e3-4237-ac6f-1aaf984d11d8</Data>
<Data />
<Data />
</EventData>
- <EventData>
<Data>Toepassing: ProppFrexx ONAIR.exe Framework-versie: v4.0.30319 Beschrijving: het proces is beëindigd als gevolg van een onverwerkte uitzondering. Uitzonderingsinformatie: uitzonderingscode c0000005, uitzonderingsadres 00007FFE8CA947A0</Data>
</EventData>
and also
Foutbucket 1255009532771649390, type 4
Naam van gebeurtenis: APPCRASH
Antwoord: Niet beschikbaar
Id van CAB-bestand: 0
Handtekening van probleem:
P1: ProppFrexx ONAIR.exe
P2: 4.1.3.1
P3: 5d66ce7d
P4: msvcrt.dll
P5: 7.0.18362.1
P6: f5bdefd7
P7: c0000005
P8: 00000000000747a0
P9:
P10:
Any idea?
Kind Regards
Bernard
Re: pf crashes after some time
Unfortunately the given error is a generic .Net Framework error. This is typically be thrown, if any other system issue occurred.
This might be a system driver issue leaving the application in an unstable state or any other external error
Have you done a system update recently, eg. a Win10 update which was unattended. And did not reboot? Or any other system driver update?
Or are you accessing the PC via RDP?
doobeedoo
Post by doobeedoo »
There were a bunch of windows updates ...
I will try to do a fresh install on another machine and see if that resolves the issue. I'm not using RDP.
Thanks for the quick reply.
