After the advertising block the station is silent
Contacto FM
Post by Contacto FM »
Hi Berd ,. You know that I have a huge problem, it turns out that I am in another city and I have to musicalize the station and I also have an advertising block.
The advertising blocks are programmed to sound and 55 of each hour o'clock (Auto Mode) The advertising audios sound and the station is silent, the auto play is not activated
What do I have to do so that after the commercial block I continue in automatic mode?
Re: After the advertising block the station is silent
The default behavior (when you have set the ‚Suspend‘ option with an overlay) is, that the overlay automatically resumes the program once it is finished. Ie it turns on AutoPlay again.
However, if the subsequent program‘s StartType is set to Manual or Auto - it might leave the AutoPlay mode off! As in this case the program is defined to start manually.
Could this be the case in your situation?
Else you might have disabled AutoPlay yourself manually via a control-command?!
Contacto FM
Thanks for answering Berd, Right now I look at those details to see if this case, Why the whole weekend I left it just playing music on the Radio was silent
? I do not understand
