Trouble using EXEC_SEND_HTTP_POST with credentials
fred48fm
Post by fred48fm »
I can't find a way to use EXEC_SEND_HTTP_POST correctly ...
It works without credentials, but when I add credentials, i got "Error : HTTP web request failed"
I tryed like this :
EXEC_SEND_HTTP_POST user|password|http://server.com/myuri|var=value&var2=value2
If anyone got an idea ?
Thank a lot :-)
Re: Trouble using EXEC_SEND_HTTP_POST with credentials
If it works without credentials, it indicates, that your server doesn't support them. So why do you add them then?
E.g. you only need credentials, if your server requires them, e.g. in a SSL/TLS environment when using https://...!
Another option when such an error occurs is, that the credentials are invalid.
fred48fm
Post by fred48fm »
We used this server and credentials on our previous system without problem.
When I say, "it work without credentials" it's just that i got a response from server (requesting me for login/password).
Strange...
What are the exact specifications of your server or API?
EXEC_SEND_HTTP_POST uses the content type "application/x-www-form-urlencoded" and provides the username:password as 'Basic' encoding in the header of the web requet (pre-authentication) and supports TLS1.1, 1.2 and 1.3.
EXEC_SEND_HTTPPOSTPLAIN doesn't provide and special content type and posts the content as plain text.
Maybe also need to use EXEC_SEND_HTTP_GET which uses a simple web request?
fred48fm
Post by fred48fm »
No idea, it's not in the system doc...
Just this :
API Usage
In order to use the API you will need an HTTP client that is capable of HTTPS communication,
pre-emptive authentication, setting request headers, reading response status codes and reading
the response body.
https
The API requires the use of simple HTTPS in all communication.
For information, the server doc says this when using curl :
curl -u yourusername:yourpassword -v --data "rpId=YOUR_RPID&startTime=2013-10-01T08:27:00&duration=600&title=SONG TITLE&artist=ARTIST" -X POST "https://___________"
For the time (will look further in this another time), I use a php script between proppfrexx and the server. EXEC_SEND_HTTP_POST send the data with no authentification to the php script. The script take the same data and send it to the API.
Thanks
That sounds like the API from radioplayer.org.
I just had a test with them (Anna Pettersen) and its is working fine.
Unfortunately their https URL as given in docs was incorrect - so after providing the correct one all was working well.
Here is the command we used with the 'Streaming.OnSongTitleChanged' event:
EXEC_SEND_HTTP_POST username|password|https://ingest.mereradio.dk/ingestor/metadata/v1/np/|rpId=yourid&*[DATE:{${now}}:{utc}:{0}:{o}]&duration=${playtimesec}&title=${title}&artist=${title}
Note: Make sure to use the latest v4.1.3.1 of ProppFrexx.
fred48fm
Post by fred48fm »
Perfect !
That's exactly the piece of script I was looking for :-)
Thank you !
fred48fm
Post by fred48fm »
After few tries, the working command for Radioplayer API is (in our case) :
EXEC_SEND_HTTP_POST user|password|https://ingest.__________/ingestor/metadata/v1/np/|rpId=_____&startTime=*[STRING:{*<DATE:{${now}}:{utc}:{0}:{o}>}:{rpad}:{19}]&duration=*[TOINT:{${cpltimeremain}}:{round}]&title=${cpltracktitlecurrent}&artist=${cpltrackartistcurrent}&imageUrl=https://___________/cover_${VAR:time}.jpg
Thank you for your help !
RadioMaxDK
Post by RadioMaxDK »
Thanks to Bernd, this worked for my setup:
EXEC_SEND_HTTP_POST User|Password|https://ingest.mereradio.dk/ingestor/metadata/v1/np/|rpId=1234&startTime=*[STRING:{*<DATE:{${now}}:{utc}:{0}:{o}>}:{rpad}:{19}]&duration=*[TOINT:{${playtimesec}}:{round}:{0.5}]&title=${title}&artist=${artist}
marvex
Post by marvex »
Is there ssomething has changed between 2019 and now - in terms of sending information to radioplayer.org
directli from terminal I can send information with command: curl -u [email protected]:xxxxxxxxx -v -X POST "https://np-ingest.radioplayer.cloud/?rp ... ist=Artist"
Now i am trying to customize it with EXEC_SEND_HTTP_POST command
[<username>|<password>|]<uri>|<content>
put marks one way and the other and can't get it to work, first, he swears something about using a script.
And for the end result: is ERROR:
HTTP web request failed: Invalid URI: The URI scheme in not valid.
EXEC_SEND_HTTP_POST [[email protected]|xxxxx|]https://np-ingest.radioplayer.cloud/?rp ... t=${artist}|
or
or
