Mapping Keyboard shortcuts?
Nuno69
Post by Nuno69 »
Hi! i am a blind user of yoru software. I come from Poland, its my first post here, chence the introduction.
How can I map keyboa5rd buttons to the application actions?
Re: Mapping Keyboard shortcuts?
In the general settings there is a section called ‘GPIO’. There you’ll find the so called Hotkey mapping. When enabled you can map for an individual key code and assign a control-command.
A control-command is a predefined action which carries out a certain command within ProppFrexx, eg. to start or stop the DJPlayer A.
A list of all control-commands can be found in the appendix of the user manual.
Nuno69
Post by Nuno69 »
That's what I read in the manual, however when I enable the hotkey mapping I cannot see anything related to mapping! BTW the Devexpress interface is a pain in the neck when it comes to accessibility for the blind but I'll use that software anyway because it's great!
Well, next to the enable checkbox is a combobox, which has a 2nd button at the end. When you click on this one it opens the mapping dialog.
Nuno69
Post by Nuno69 »
No, still no luck. The only button I have near the keyboard checkbjox yells at me that there's no a s serial server started.
In the 'Keyboard Hotkey Mapping' group there are the following items (from right to left):
1. Use Global Capture (checkbox)
2. Mapping (label and combobox), this on has 2 buttons at the end (1st the combox button, 2nd the effective mapping button)
3. Keyboard Hotkey Control Enabled (checkbox)
Nuno69
Post by Nuno69 »
Thank you! I will be checking and trying to do it. By the way if you would get external help from people like me, and fellow blind broadcasters, would you be willing to include some more accessibility?
Nuno69
Post by Nuno69 »
Hi, I managed to open up the dialog, however I needed to use a very special screenreader operation method to open the dialog. By the way, edit boxes have no readable label for the screenreaders.
I fully understand your issue.
But providing perfect accessibility help for blind people is a real challenge for a non-blind person.
And I assume, that providing full screen-reader support for all editors, dialogs and other controls is probably a huge work load, which I am not sure I am able to provide?
Nuno69
Post by Nuno69 »
The textboxes have a label for sighted people, so why just not bind them to the AccessibilityController? It should be doable.
