TCP/IP command not received
This forum is unmoderated!
mixmog
Post by mixmog »
I'm trying to send TCP/IP command from one instance of PF to another.
When sending test message from PF (A) to PF (B), the result is "OK", however, no command is enacted on PF (B).
I know the syntax is correct because I can successfully trigger the command from Packet Sender - the command is enacted on the target isntance of PF.
What am I missing?
The command is:
192.168.1.71:8052|AUTHORIZATION myriad\r\n\r\nMIXER_INPUT_VOLUME_SET S1|1.0\r\n\r\n
Re: TCP/IP command not received
Please try to replace the \r\n by ${CRLF}
E.g. use: (all in one line!)
EXEC_SEND_TCP 192.168.1.71:8052|AUTHORIZATION myriad${CRLF}${CRLF}MIXER_INPUT_VOLUME_SET S1|1.0${CRLF}${CRLF}
mixmog
Post by mixmog »
That did the trick - many thanks!
