Add cartwall to floating window
Soulmaster
Post by Soulmaster »
i'm , as you see on the screenshot, using floating windows. i'm using cartwall II but i want also going to use cartwall I as floating window. but don't know howto do this..
Re: Add cartwall to floating window
I am not sure what you mean - just like any other.
Just drag and drop it from the title bar.
Soulmaster
that doesn't work :( i've i press control+1 no cartwall 1 is opening :(
If a (floating) window is already visible (as in your screenshot) it won’t open again (as it is already shown)?!
So I am not sure what is expected.
Soulmaster
i know but that is cartwall II and i want 2 cartwalls cartwall one and cartwall 2. . got it on the other proppfrexx i'm running
I am sorry, but I do not understand what you want to achieve and what your issue is.
In both screenshots (the original one; as well as in the one above) I am seeing Cartwall I and Cartwall II.
Both are visible.
Please explain in more detail what you want to achieve and what is not working?!
CTRL+1 shows Cartwall I and this is just working fine here and it works the same way as CTRL+2, which shows Cartwall II.
Soulmaster
well on the first screenshots there is only one cartwall visible not two . and even by pressing ctrl +1 no cartwall one is showing up .
I don’t know what happened in your case.
To reset the entire layout, please close PF and delete the file called „ProppFrexx ONAIR.layout“
This will reset all windows and makes all windows appear in their default location again.
Soulmaster
Fixit :) restored the standard template and now its working :)
Soulmaster
Much better :)
