overlay scheduler issue since last update
moogwill
Post by moogwill »
Hi bernd,
since last update there's an issue regarding the overlay scheduler. When I tried to open it, there's a graphic bug with an error window that freeze PF when pressing continue.
Re: overlay scheduler issue since last update
What error do you exactly get? Anything logged to the Error.log file?
I cannot confirm this issue here - it opens normally here. I also asked some other users and it works fine there as well.
moogwill
Post by moogwill »
Out of the studio till tomorrow... will send you more info then
moogwill
Post by moogwill »
ok I pressed send error report but here's a screen cap
Please send me your Overlay.calendar file to check. Thanks!
moogwill
Post by moogwill »
cant find any overlay.calendar are you sure of the file name?
here are those i can find
ProppFrexx ONAIR.zip
(9.03 KiB) Downloaded 467 times
Yes, it is contained in the root folder of your defined ‚Advert Storage Path‘ - see the general settings section Scripts/Scheduler.
moogwill
Post by moogwill »
ok stored on the network for me, that's why i wasnt able to find it, here it is
Overlay.zip
(8.64 KiB) Downloaded 470 times
moogwill
Post by moogwill »
Note that overlay scheduler is working correctly.. but I cannot open & edit it...
A v4.1.1.1 - update is available, which should fix this issue!
