Voicetrack
Frans
Voicetrack
Post by Frans »
I have updated into V4.1.0.1.
I am since then experiencing problems with voicetracking.
Playlist -> Push Voictracking (microphone).
Sometimes the voicetrack screen opens and works as usual. But after some voictracks the voicetrackscreen freezes while opening. The only option then is to reboot Proppfrexx.
I have tested this with and without my (external) sound card, but there is no difference in the freezing problem.
So, can you look into this, please.
Another question: when upgrading Proppfrexx makes a backup of the older version, I think. Where is the backup saved?
Thanks in advance.
Greetings,
Frans
Re: Voicetrack
It is saved under the 'Previous Version' folder in your install directory.
Unfortunately I cannot reproduce your issue.
The screenshot looks like a graphics issue.
Maybe you also had another update of a driver in the same time - have you already tried rebooting your machine?
Re: Voicetrack
Any News?
