Using news in overlay
WimHP
Post by WimHP »
Question regarding the use of the news in overlay
For the news I use an overlay setting every hour. However, the news bulletin is not the same length every hour. What kind of setting should I use for this with the LoadTrack when I download the .wav file?
Thanks for the answer
Wim
Radio Dutch Palette
www.hollandspalet.nl
Re: Using news in overlay
This doesn’t really matter. When you use the Overlay Scheduler with the ‘’News’ Type, the length of the overlay doesn’t have to be the same.
The only thing to take care is in case you set the ‘EndsAt’ start type, that you specify the ‘Show in Advance’ time big enough, greater than the max. duration.
WimHP
Post by WimHP »
Hello Bernd, thanks for the fast and clear answer! Great!
Wim
Radio Hollands Palet
