What to do!
yourx
What to do!
Post by yourx »
question if the scheduler is running, and I create a new playlist to create a new programma than this new playlist start automatically after a few minutes. How can I prevent this.
Re: What to do!
It depends when you are editing the manual playlist.
I cannot really reproduce this here, but it might depend on your environment and if you are using certain control-commands.
However, it is recommended to not mix the automation mode and the manual editing on the same ProppFrexx instance.
Ie. do this on either a 2nd machine or on a 2nd instance.
yourx
Re: What to do!
Post by yourx »
can i make a 2nd instance on the same computer for making playlist and voice tracking.
Re: What to do!
Yes you can.
By default it will use the exact same (audio) settings and other options. If that is not wanted you can use the -config command-line option when starting ProppFrexx to specify an alternative configuration folder. See the user manual for details.
Re: What to do!
Yes you can.
yourx
Re: What to do!
Post by yourx »
Thanks it works ;-)
