script problem
atlantic
script problem
Post by atlantic »
I cannot create a script. I cannot select folders.
see picture.
version 4.05.31
regards
marc
Re: script problem
What if you size the popup window at the bottom right? Does this show the OK/Cancel button?
Else, does pressing the ENTER key help (after you selected the related entry)?
But you are right - this needs to be fixed!
atlantic
Re: script problem
Post by atlantic »
if I adjust the pop window, the ok / cancel button will not appear.
I also cannot scroll in the pop window.
I can select a folder by pressing enter.
Re: script problem
A new v4.0.5.33 update is available which fixes this issues!
